跳转到主内容
加入维修社区 - 创建账户
Long Screws Won't Screw In!
Hello! I was recently opening up my Macbook Pro for the first time, and all was well, but when I went to screw everything back in, the back three screws (the long ones) WILL NOT GO IN! All they do is just screw in a tiny bit then get insainly difficult to screw in, and I don't want to strip them, so I pull them out. Please help ASAP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
P.S., The MacBook is from around 2011-2012 I believe.
完成的
What are the last four digits of your serial number?
完成的
Not sure how to find this @robert
完成的
It should be located on the bottom cover in this area
完成的
DV13 is the serial number. @robert
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
It really sounds like you are talking about the bottom cover. With the machine inverted and the hinge facing away from you, the long screws go into the three holes at the top of the machine to the right. The far left hand screw in the back is a standard one. The short screws sound like you have them in the long screw holes. Gently lift the bottom plate up with your fingernails, as they really aren't attached and they should come out with the cover. Next time follow the guide.
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*2011年末13寸 MacBook Pro 一体化机型底壳更换
这个答案有帮助吗?
得分 2
添加一条评论
Are the screw holes I highlighted in blue obstructed in any way?
这个答案有帮助吗?
得分 1
4条评论:
I cant quite tell because unfortunately, now the other screws wont come OUT.
完成的
A few of them, at least.
完成的
The top right three screws won't come out. They aren't stripped or anything. They just keep spinning and spinning. But from what I can tell, the screw holes aren't obstructed.
完成的
The threads may be stripped, if you take a pair of needle nose pliers, can you get any leverage?
完成的
添加一条评论
添加你的答案
Kerp Kat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 8,230
