跳转到主内容
Information and repair guides for dehumidifier repair, an appliance that removes humidity from the air in your home.
How to drain dehumidifier bucket
How do I switch from having the bucket collect water to having it drain through the tube attached at the rear bottom? The bucket has no drain plug, and when I remove the bucket the unit stops working. Help, please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
I could not find a teardown of this model but it has an option listed as "Continuous Drain Mode With External Drain Connection". There may be a valve that directs the water flow directly to the external tube and bypasses the bucket. I would check your users manual on how to set it up.
这个答案有帮助吗?
得分 4
1条评论:
+ research
完成的
添加一条评论
There is a tiny black plug which, if inserted into the hole on the very top left, will divert the water flow to the back. I believe the tiny black plug may be in the top right ready for you to take it out and put it in the top left drain.
Now, my problem. After several years of having a daily flow of water I now have no water produced at all anymore. The humidity is quite high 79 and the setting is for 60. What could make it just stop taking the water out of the air?
这个答案有帮助吗?
得分 2
添加一条评论
I ended up simply drilling a 1/2" hole in the front of the bucket with two #8 machine screw holes for the ears on the hose adapter. Put silicon glue around the hose adapter, slid it through the hole and secured it with the #8 machine screws, lock washers, and nuts. I no longer have the problem of the bypass pipe freezing up and blocking the bypass and filling the bucket instead.
这个答案有帮助吗?
得分 1
1条评论:
@rlstrommen58 - can you tell us more about the "Continuous Drain Mode With External Drain Connection" option?
完成的
添加一条评论
I am still having trouble getting the drain to work at that back instead of the bucket.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Clare Hushbeck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 5,085
