Qi modification sticker NFC
Will it be possible to install this insted of the NFC only sticker on D6603?
I do not believe there is a QI receiver. I think these are falsely advertised where the seller is not aware of what the product is.
这个答案有帮助吗?
What about the wireless charging cable on IFixit store? [关联产品丢失或禁用: IF312-057] isn't it a QI receiver? or is that for the magnetic charger?
Correct. The one on iFixit is for the magnetic charger. The Experia Z3 has a separate magnetic charging accessory.
Thanks for clarifying. I got confused, since it says "wireless charging cable".. alas, "wireless cable", now that I think about it, sounds really dumb.
The easiest way to convert the Xperia Z3 to Qi Wireless charging is to use a Qi case, if you don't mind the bulk.
https://www.amazon.com/cellphone-Cases-A...
Apparently all the table chargers at Starbucks are being to converted to Qi.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 612
