跳转到主内容
加入维修社区 - 创建账户
1.8GHz 双核 Intel Core i5 或 2.0GHz 双核 i7 处理器。(Turbo Boost 最高可达 2.8GHz),配有 3MB 共享三级缓存
Isolating MacBook no power issue
Hi Everyone,
I have a 13" Mid 2012 Macbook Air that has stopped turning on.
I have tried multiple known good chargers - no light on any of them.
SMC Reset, unplug battery + power button all did not help.
No activity at all upon powering on. There are NO battery status indicators on this model to tell if battery is charged at all..
I assume that it is either the logic board or the I/O..
Is there a way to isolate this between a faulty logicboard and a faulty I/O Board?
I understand the $90 I/O Board would be a better place to start then the $400 logic board - but was curious if there was anything I could do to test for sure which is the failed component. Is there a way to send power to logic board bypassing the I/O Board? It's likely the battery is completely discharged so I don't think shorting the pads did not seem to work, due to I'm guessing no power in the system.
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
There's really no way to tell until you drop in a new battery, get it started and run diagnostics.
这个答案有帮助吗?
得分 1
2条评论:
Is there no way to power the mainboard directly?
由完成的
I have a similar problem with my MacBook Air Mid 2013. Was working great the previous evening, then the next morning it would not power on. Plugged in with a new power cord - nothing. Replaced the I/O board, nothing.
Does this narrow it down to the logic board?
由完成的
添加一条评论
添加你的答案
mikejensen13 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 856
