跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
20 个问题 查看全部
Using DDR3 PC3-10600 rather than DDR3 PC3-8500
Hi all,
Has anyone tried putting in the larger DDR3 PC3-10600 ram into the mac mini mid 2010 rather than the recommended DDR3 PC3-8500.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Here's a good reference: DDR3 SDRAM
完成的
添加一条评论
2个答案
已选择的解决方案
Sure the faster (newer) modules will work. But you don't gain anything as the systems memory access speed is fixed.
I would just buy the cheaper modules. Also remember the systems limit is 16 GB.
Before you do anything make sure your firmware is upto date. Follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
I have run into some machines where the faster RAM DDR3 PC3-10600 would not work in a DDR3 PC3-8500 native machine. I know it should but it didn't. This was last seen in a 2010 15" MBP.
这个答案有帮助吗?
得分 4
3条评论:
Thanks Mayer, I'll consider this before I buy.
I wonder if Apple have a software hack to stop it...
完成的
Same here, put 10600s into MM 2010, three beeps only. Will not run.
完成的
@chrishees - Check the PCH logic as the older series won't support the newer SO-DIMM's.
完成的
添加一条评论
添加你的答案
Nim Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 10,634
