跳转到主内容
Information and repair guide for the Samsung RF220N*TA** refrigerator—a 2014 bottom-mounted freezer model with French door access and compact design, suitable for built-in usage in limited spaces. This page covers information for model numbers matching the pattern RF220N*TA**.
3 个问题 查看全部
Why are my fridge and freezer not cold enough?
We noticed about two weeks ago that our 3 yr old Samsung Fridge, model rf220nctasr, is not cold enough (both fridge and freezer). Since then, we replaced the evaporator fan and cleaned the condensor coils. No change.
Other observations:
- The condensor fan seems to function adequately. It does sometimes run even if the compressor doesn't (we noticed that once).
- The compressor is really hot to the touch.
- The evaporator fan runs and pushed cold air when the light in the freezer isn't on. Can't confirm if it stops working however.
- The evaporator coils are not evenly frosted.
- We do not hear any clicking noise.
- Self diagnostic returns no error.
Repair person seems to think we should replace the freezer evaporator and filter dryer, but from my research, if the evaporator was defective, there would be an ice build up ?
Thank you!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The key symptom is the hot compressor. My first thought would be low refrigerant level and this requires a licensed technician.
Here's how to check it out:
https://fridgeman.wordpress.com/2008/06/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sindyhoule 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,397
