跳转到主内容
加入维修社区 - 创建账户
Laptop screen very dim
Can barely make out images on laptop screen. Screen displays fine on external monitor. Thought it was the inverter board, so replaced, but same problem. Replaced logic board, still same problem. Any ideas? Brightness is whole way up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If I read you correctly you have replaced the inverter board and the logic board. The unit functions well with an external monitor. It would seem that leaves only the cable from the logic board to the inverter board or the LCD itself. I would try the cable as the lower cost part first. I am including the link for replacing the LCD but hope you won't need it. Good luck Ralph
PowerBook G4 Aluminum 12" 1-1.5 GHz Display Replacement
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
最有帮助的答案
There's only the LCD & the Display Data Cable (LVDS) left and it doesn't sound like the cable.
这个答案有帮助吗?
得分 2
1条评论:
I've got to learn to type faster. + Ralph
完成的
添加一条评论
添加你的答案
sdheck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 1,574
