跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
A1181 Core Duo MacBook randomly restarts and goes into kernel panic
I have an A1181 Core Duo 2006 Macbook that randomly restarts when a known good battery is installed and finally ends in kernel panic. When I take the battery out, it runs just fine. Without the battery installed, I let it run for a few hours, browse the internet, go into control panel, all the normal things with no problems. But when I add the battery, the restart circus begins and then the kernel panic. One thing I have done is re-apply some newer thermal grease to both the cpu and the graphics processor which seems to have helped stabilize things. But when a battery is added, the restarts resume. I have a newer battery which I've charged and tested. Pushing the button on the battery shows all green.
My question is, would replacing the battery connector fix this? Since the macbook works fine without a battery, I don't think its a logic board issue. I've taken the battery connector out, blew compressed air on it and on the board where it plugs in but that in itself did not fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
A kernel is the code on which the is is based shut down and insert the battery then reinstall is x
这个答案有帮助吗?
得分 0
1条评论:
Yes I know what the kernel is thank you. The problem was using the MacBook with the battery. Without it, the MacBook operated normally. At least until a little while ago, I decided to wipe the drive and put a fresh install of Leopard on it and the whole thing crashed. Have ordered a logic board from eBay in hopes that will fix it.
完成的
添加一条评论
添加你的答案
Gordon Fikes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 139
