跳转到主内容
加入维修社区 - 创建账户
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Power switch cable damaged
In the process of removing the logic board the power switch cable was unintentionally ripped from the back of the power switch. Is there any way to remove the switch so I can attempt to resolder the wire to the switch?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did this solution work? I have the same problem. Any tips?
完成的
添加一条评论
1个答案
已选择的解决方案
That switch is usually held in place by 3 plastic globs that are integrated into the back frame. I have used a chisel to break them off and then re-glued it back into place after replacing. It not a pretty repair, just a hack.
这个答案有帮助吗?
得分 4
2条评论:
This answer is not a very good It is very silly
完成的
Well Manuel, just how do you proposed to repair it? Have you even looked at one?
完成的
添加一条评论
添加你的答案
mike motuliak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 276
