跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
720 个问题 查看全部
Should there be any standing water left in the sump?
This is a basic GE dishwasher approx 10 years old (GSD3320C06BB). I was having standing water visible in the tub after finishing (about an inch). I used suggestions offered here in other posts and now it is draining much better. However there is still some water remaining in the sump (I have the sump covers/protectors off). You would not see this water if the covers were in place. Is this normal? I've read elsewhere that some water is supposed to remain so that pump seals don't dry out. Or perhaps I have a check valve in the drain system that isn't functioning correctly. Parts diagrams do not show any check valve so perhaps it would be embedded in the hose or pump itself? Observing the drain cycle, it appears that most of the water is pumped out of the sump as it runs but as soon as the cycle ends, and the pump shuts off, some water flows back into the sump, stopping just before reaching the tub itself. Otherwise the drain flow into the disposal seems to be very strong now. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
You were right the first time. If you have standing water below the filters
your fine. That is normal to keep seals
from drying out. Water above filter line is a problem.
这个答案有帮助吗?
得分 1
添加一条评论
i have old g&e over 10 year if with the cover you can't see the water it is ok.. my dishwasher has water in the pomp to when sametime i do a clean up..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Majors 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 98
总计 7,548
