跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
The phone doesn't charge after falling into butter and my awful repair
Couple of days ago I accidentally dropped my Iphone 3g into the melted butter :( so it fell with the bottom side. I cleaned it and then left to dry. Today I turned it on, but the sound of music was too quiet and people I call could hardly hear me.
I decided to take the phone apart, and to clean it from the inside. Everything went ok up to the moment when the dock connector block had to be taken out. It was a hard to take it out with fingers, so I tried to push with a screwdriver from the outer side right in the upper center of the port (i know, it was a bad idea). At some point the screwdriver pierced the plastic and went just under the board which is connected to the port.
After that I looked over this part, thought that nothing is broken. Then I cleaned everything and assembled the phone. The sound was perfect, but when I tried to charge the phone it failed.
Couldn't find a way how to post images here. To make things clear, please, click here. The photos are on Dropbox.com.
Now the phone is off because the battery is empty, and I don't know what to do. If anyone has any idea, please, tell me. Is it the butter, or is it the hole from screwdriver?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You probably need to replace the dock connector piece; you may have shorted the charging connectors out with the butter. I'd try replacing the connector and see if that does anything. You can get the part here and follow this guide.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Temirlan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,664
