跳转到主内容
A 65" rear projection TV by Mitsubishi.
7 个问题 查看全部
Mitsubishi tv won't come on
Green power light comes on ,goes off, no pic ever comes on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
Green light comes on and go's off
完成的
添加一条评论
2个答案
Judy Bush, check all the pico fuses on the board. There should be either 4 or 6. Check for continuity. Most likely that two are shorted out. This model has issues with the Convergence Correction Circuit IC STK393-110. Now it is up to you and your skills. Always make sure that you unplug your TV and leave it unplugged while you work on it. The caps will hold power for quite a while and you would not want to get zapped. You will need a multimeter and a few other tools to try and fix your set.
这个答案有帮助吗?
得分 0
添加一条评论
I have no picture..but full sound??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Judy Bush 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 12
总计 1,161
