跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How do I bypass the code of a water damaged iPhone 5?
I Have a customers IPhone 5 that is watered damaged. I have dried and brushed the IPhone with alcohol. The phone works but the screen will not turn on. I can hear seri and the vibrator. I just need to extract the info. How can I do the without the screen working?
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
did you check the components around the LCD connector?
完成的
添加一条评论
1个答案
If you're hearing Siri, cleaned the motherboard etc. with alcohol, there's just the contaminated LCD + Touchscreen, you need a new one.turn off your iPhone with replacing the batterie and than get start changing the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chapsh2o 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 117
