跳转到主内容
Trackpad and keyboard with MacBook late 2008 exchangeable
Hello
I have got parts of a MacBook from late 2008 (the 2 GHz ones, not a Pro) and I have got an early 2011 13" MBP where trackpad and keyboard are not working any longer.
Can I exchange the pad and the keyboard with the ones of the MacBook? And will they work correctly?
Regards, Stone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi! Actually the keyboard can be transferred from late 2008 MB to Late 2011 MBP, if you really need to. (Did this just a minute ago). But unfortunately the trackpad is too different to fit. Keyboard will function just fine, all the screwholes doesn´t match.
完成的
添加一条评论
3个答案
已选择的解决方案
Sorry, but no.
As I've mentioned before, Apple stupidly recycled the A1278 model number for two very different machines. In 2008, they used it for the Aluminum MacBook (the first Unibody MacBook), and then they recycled the same number in 2009-2015 for the 13" Unibody MacBook Pro.
The two versions have nothing in common except the Apple name, aluminum cases and 13" displays; they have no common components between them.
As you can see, there are no overlapping part numbers between the two computers, because no matter how similar the parts look, they are not identical.
I too have both a 2008 Aluminum MacBook and an Early 2011 13" MacBook Pro, both with their own quirks, which might be solved by swapping parts between the two...but the parts can't be swapped. I feel your pain.
MacBook Unibody (A1278) Upper Case (Backlit)图片
产品
$99.99
MacBook Unibody (A1278) Trackpad图片
产品
$64.99
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad图片
产品
$59.99
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case图片
产品
$39.99
这个答案有帮助吗?
得分 4
添加一条评论
Hello
Sorry, but had some problems to access ifixit - got some errors while posting an answer; hopefully it will work now.
As I can seen there not much parts exchangeable.
But if I am right, and what to mention from stores, LVDS cable seems to be exchangeable with MacBook Pro 13" early and late 2011? And also the TFT / LCD itself?
Regards, Stone
这个答案有帮助吗?
得分 0
1条评论:
Not exactly. The 2008 MacBook Aluminum can swap LVDS cables and LCD panels with the 2009/2010 A1278 MacBook Pros, but not with the 2011 or 2012 generations, which each use their own unique parts. The 2008 MacBook and the 2009/10 13" Macbook Pro both used Nvidia GPUs, while the 2011 and later 13" MBPs have all used Intel graphics chipsets.
完成的
添加一条评论
The 2008 MACBOOK a1278 keyboard fits 2009-2012 a1278 and works exactly as it should. Don't know about trackpad, my screws were rusted but connection looks the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 2,067
