跳转到主内容
Repair for LED, incandescent, and other handheld electric light sources.
28 个问题 查看全部
What LED flashlights are best for hunting/fishing?
I am looking for some flashlights for hunting and fishing. When I check the Surefire site, I thought the flashlights are good, when I check Tank007 tactical flashlight, they seems good as well, So, what hunting flashlights do you use? Which one is better?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
#1 WATERPROOF
  1. 2 heavy enough to knock the prey out with the first blow
这个答案有帮助吗?
得分 1
1条评论:
Shockproof helps there too
完成的
添加一条评论
There are many LED flashlights on the market. You should read this review to pick the best one for you.
这个答案有帮助吗?
得分 1
添加一条评论
It depends, note if your flashlight uses 18650 and beware of those cheaply made ones.
you can visit http://flashlight.nitecore.com/
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
katherinegreen550 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 512
