跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
No video after liquid spill
Louis, I have a FD57 dual graphics in with a liquid spill. I replaced the keyboard. Machine runs fine except for no internal display. I saw no evidence of logic board contamination. External monitor works fine. A flashlight shown thought the Apple shows the desktop. The retinas are new to me - I only get the old sh*t to work on. On a C2D this would be the inverter. So I assume it's something like a LED driver board but where is it and how do I fix it? Please teach me because I bought this machine.
UPDATE
Board# 820-3547a
Pin #1 battery disconnected in Diode Mode reads 0.423
Pin #1 Battery connected & machine on reads 4.97
Pin #1 Battery disconnect & LCD disconnected 0.582
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
HDMI SD Card Module 820-3547-A
完成的
read 820 number off main logic board, not right i/o board
完成的
添加一条评论
1个答案
已选择的解决方案
Are you sure that's the right 820 number? I can't find any retinas with that. 820-3787 or 820-3662 are the ones for late 2013. Hopefully this is 3787 because 3662 has nothing in terms of schematics.
No diode mode measurements with power running through, it will let the smoke out!
Measure voltage on pin 1 of LCD connector with it on. 0v, 12.6v, or something higher? 0v means something is gone completely, 12.6v means something is there but the circuit just isn't boosting.
这个答案有帮助吗?
得分 4
12条评论:
Louis: just to be sure I've got it right, the #1 pin is to the back edge or to the center of the logic board? And yes, the battery is disconnected and isolated before using the diode mode. Using Fluke 87 for measurements. I will double check the 820- number but am sure Richard sent you the one imprinted on the motherboard. Thank you for your help on this.
完成的
It's the pin all the way to the right when oriented so the LCD cable plugs in on the top. 820-3547a is a USB/HDMI/wifi board, not a logic board, please get 820 number from actual logic board!
完成的
Thank you for the pin info. I'll get that info most likely Sunday or Monday and resend it to you. Sorry I missed the right board. Will get that to you at same time. Thank you very much for your help and patients . Ken
完成的
Louis, I'm covered up right now. How about if I just send it to you? Can you email a link to where to ship it and an estimate? Thanks
完成的
Mac Laptop Repair Specialist, 186 1st ave, frnt 1, New York, NY, 10009. Price depends on what winds up being wrong with it. Just put a note in the box with contact information and you'll hear within a day, any no backlight issue on any Apple board is a 90 second job at this point so feel free to tell customer turnaround time that is just the shipping both ways and nothing more.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 913
