battery A1416 IPAD WI-FI THIRD GENERATION
HI,
WHEN I CLICK THE LINK FOR BATTERY A1416 TO ORDER IT, ITS SHOWS ME THE BATTERY A1389. IT IS NORMAL ? I DONT WANT TO BUY THE WRONG BATTERY AGAIN. THANKS FOR YOU HELP!
JENNIFER
MONTREAL, CANADA
HI,
JENNIFER
MONTREAL, CANADA
I do not care for the way Apple numbers its batteries as it makes them look like model numbers instead of part numbers. Here’s your correct battery:
COMPATIBILITY
SPECIFICATIONS
Part #:
616-0593, 616-0592
Model #:
A1389
Watt Hours (Wh):
42.5 Wh
Voltage:
3.7 V
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 463
1条评论
A1459 Does not show that it is charging at all. Connections seem tight and clean. Tested with various cables and chargers. Would this likely be just the battery itself, or any other possibilities?
由 Bryan Harms 完成的
