跳转到主内容
加入维修社区 - 创建账户
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
mower won't start when hot.
after cutting half the lawn the mower stops and will not restart.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
,check fuse, it bad, replace I would replace it anyway, sometimes they look his but arent
完成的
My battery is good but when I turn the key I get zero turn from the mower
Engine. The light near the ignition isn't lighting up either.
完成的
添加一条评论
3个答案
已选择的解决方案
First check the vent in the gas cap. If it is not working, a vacuum will build up in the tank and starve the engine of fuel. After it sits for a while the pressure will equalize and it will be able to get gas again. Also if it has coolant, check the level.
这个答案有帮助吗?
得分 3
3条评论:
I have this problem on a 2 cycle string trimmer. How do I check the gas cap?
完成的
I'd ask a new question on this. I do not have an answer.
完成的
You could just open the cap and release the negative pressure. Instant equalization. If it restarts, replace the cap. Can't be too expensive.
完成的
添加一条评论
If the starter motor turns slowly like the battery is discharged , it could be a faulty winding. Some small engines use the same circuit running through the starter to the ignition system. If the starter motor is drawing too much juice it will cut back the power available to the ignition.
这个答案有帮助吗?
得分 2
添加一条评论
I had the same problem and it got progressively worse by shutting off sooner and sooner over one summer. I had the carburetor serviced, but still had the problem. The final solution was to replace the fuel shut off valve in the bottom of the carburetor. This part appeared to be ok, but engine heat buildup would make it fail--an inexpensive repair to a vexing problem! My sincere thanks to a local "back-yard" mechanic who gave me this tip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gclcars 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 19,747
