跳转到主内容
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
79 个问题 查看全部
cannot find a way to connect wifi
So i just got a cheap nice asus laptop/netbook today and i tried to find the wifi connections but i couldn't find it , i don't know where is the place can connect the wifi, is it don't have any wifi connection ? Some plz help me .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
7条评论
someone please help me i am !#^&@@ off right now i can not find any way to connect the wifi not even any symbol to see how to connect the wifi>
完成的
I had this problem too. Wifi/airplane mode on/off. Restarted. Followed all the forums. Updated driver software. Network adapter - properties - minimum power consumption disabled. Yep all of it. Nothing fixed it.
Finally I saw on one forum which fixed it:
Device Manager (searched for it) - Under Network Adapters - Broadcom 802.11abgn Wireless SDIO Adapter - I disabled it then enabled it. It will prompt you "Are you sure you want to do it as it will cause it not to work anymore?" Yes. I'm not an idiot. Then immediately re-enable it. Mine already was enabled. But I turned it off & on again. After 1 minute wireless bar just popped up no issues. I didn't have to reconnect to my wifi, change any settings, login, or restart. It just did it. Yay. Finally.
Stupid thing. It's possessed. Had it 2 years. I'm getting something else. Piece of S really. You only get what you pay for.
Hope this helps anyone else's connections if all else has failed like mine had.
完成的
Just wanted to say it did help me! Had the same problem, totally solved... Thanks a bunch!
完成的
Thanks. trying all of the obvious things and came across this
完成的
Omggggg!!!!! It works! My problem was, I can't connect to the wifi, everything was visible, wifi connections and all but it can't connect. Then I found this!!! Thought my notebook will be wasted now. Been using it for 3 years.... thanks soo much :))
完成的
显示更多的2条评论
添加一条评论
4个答案
已选择的解决方案
请参阅图像内容:
这个答案有帮助吗?
得分 2
3条评论:
ok yeah but i can't even see the symbol of the wifi now
完成的
Press the FN + F2 key again. This disables/enables the wifi.
完成的
please confirm if this helped your problem
完成的
添加一条评论
Here is link that will help you hook up your wifi. Tap on or click on the blue link. I think this will help.
https://www.manualslib.com/manual/677613...
这个答案有帮助吗?
得分 0
添加一条评论
I have done above steps and success several times before. However, not sure why i have encountered same issue and it didn't work anymore. Eventually, i have found my ASUS T100 been attacked by malware in registry and system32 folder that diagnosed by Advanced SystemRepair Pro. The malware files are following:
c:\Windows\System32\igfxdev.dll
c:\ProgramData\SetStretch.VBS
c:\ProgramData\SetStretch.exe
c:\ProgramData\SetStretch.cmd
I have deleted these files and some registry contain malware.
So you can try download Advanced System Repair to scan u laptop and fix it accordingly.
i found this website in other forum http://en.forumsbeitrage.com/quot-ready-...
Hope this will hep u solve your problem!
这个答案有帮助吗?
得分 0
添加一条评论
T100ta reinstall, ni wifi,[ again]it works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jinxleebrown 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 44
总计 31,326
