Under Network Adapters - Broadcom 802.11abgn Wireless SDIO Adapter - I disabled it then enabled it.
I have done above steps and success several times before. However, not sure why i have encountered same issue and it didn't work anymore. Eventually, i have found my ASUS T100 been attacked by malware in registry and system32 folder that diagnosed by Advanced SystemRepair Pro. The malware files are following:
c:\Windows\System32\igfxdev.dll
c:\ProgramData\SetStretch.VBS
c:\ProgramData\SetStretch.exe
c:\ProgramData\SetStretch.cmd
I have deleted these files and some registry contain malware.
So you can try download Advanced System Repair to scan u laptop and fix it accordingly.
i found this website in other forum http://en.forumsbeitrage.com/quot-ready-...
Hope this will hep u solve your problem!
7条评论
someone please help me i am !#^&@@ off right now i can not find any way to connect the wifi not even any symbol to see how to connect the wifi>
由 jinxleebrown 完成的
I had this problem too. Wifi/airplane mode on/off. Restarted. Followed all the forums. Updated driver software. Network adapter - properties - minimum power consumption disabled. Yep all of it. Nothing fixed it.
Finally I saw on one forum which fixed it:
Device Manager (searched for it) - Under Network Adapters - Broadcom 802.11abgn Wireless SDIO Adapter - I disabled it then enabled it. It will prompt you "Are you sure you want to do it as it will cause it not to work anymore?" Yes. I'm not an idiot. Then immediately re-enable it. Mine already was enabled. But I turned it off & on again. After 1 minute wireless bar just popped up no issues. I didn't have to reconnect to my wifi, change any settings, login, or restart. It just did it. Yay. Finally.
Stupid thing. It's possessed. Had it 2 years. I'm getting something else. Piece of S really. You only get what you pay for.
Hope this helps anyone else's connections if all else has failed like mine had.
由 Albert Einstein 完成的
Just wanted to say it did help me! Had the same problem, totally solved... Thanks a bunch!
由 Twickenham0 完成的
Thanks. trying all of the obvious things and came across this
由 mickey boaglio 完成的
Omggggg!!!!! It works! My problem was, I can't connect to the wifi, everything was visible, wifi connections and all but it can't connect. Then I found this!!! Thought my notebook will be wasted now. Been using it for 3 years.... thanks soo much :))
由 Ysh D 完成的
显示更多的2条评论
