跳转到主内容
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 个问题 查看全部
How to position the vibration motor? (Correct position of motor)
Since a couple of days my vibration motor in my HTC One m9 doesnt work as before. The intensity is about the half now. I guess somethings wrong with the motor, maybe it moved while a crash or something like this. Does he need to be fixed in the case or whats the correct position for him?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
It's soldered on the daughterboard.
这个答案有帮助吗?
得分 1
1条评论:
I know, but i thought the vibration module may be fallen out of the slot. Does it need to be fixed inside the gap?
完成的
添加一条评论
same problem as dominik has
这个答案有帮助吗?
得分 0
添加一条评论
If the vibrate motor is spinning a full cycle then I doubt the position is the problem, usually if it has moved and out of position it will not spin and get caught or you will hear it vibrate against the object it's spinning against. Contact HTC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dominik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,094
