跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
My aux plug in seems out of reach?
My auxilary plug in works on some cords, but not all of them (I have taken my case off.) It wasn't long before I found out that if I pushed down hard enough on every aux plug in I could get it to play music. With headphones, car aux cords and ihome cords it all works if I push hard enough. It seems as though the connector has become just out of reach? My brother said to put tin foil down the plug in... I've learned to not follow his advice before so not about to start now, any suggestions. It won't play music unless pushed down far enough to reach the connector
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Have you tried the original headphones (if you don't have them anymore, borrow them for the test)?
If yes, and they work without pushing down hard, then it means everything else you're using is ill-fitted.
If the original ones don't fit in properly, then it could mean that something's wrong with the headphones jack cable, and it needs replacement such as by following thi guide that has all the needed steps, tools, and parts. Note that that particular repair is a bit of a PIA.
这个答案有帮助吗?
得分 1
添加一条评论
Clean out the headphone jack port, possible some lint or fuzz ball is stuck down in there.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
brynnlyward 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 6
总计 294
