跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
1/4 of a Mojito spilled on Top Left corner of MacBook
Hey Guys! First off, THIS SITE IS AMAZING!!!!
Anyways, my cousin spilt a little bit of her beverage on the Top Left corner of her laptop. It caused it to shut down. She let me have it after dried up for a couple days. I was excited to have it and try and fix it. The Laptop turns on now only when it's plugged in. If it's not, it wont turn on at all. The System Profiler says to REPLACE BATTERY NOW. Also, NOT CHARGING. I took out the battery and plan on buying a new one. But should I replace just the battery or also the DC? Help please! Thank you very much!
Also, I went to the Apple store and a guy took a look at it. He did something by holding "N" and the power button. A screen popped up and said that usually, the option to CHECK ADAPTER pops up but it didn't. He said he felt "Sketch" about just being the battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Okay guys. I replaced the DC-In Board. Still no luck with the battery charging. So is it safe to say I can purchase a new battery now? Please respond when you can. Thanks Friends
完成的
添加一条评论
1个答案
已选择的解决方案
I would replace the DC-IN board. In the meantime open it up and clean the inside with alcohol, just to stop corrosion on the board.
这个答案有帮助吗?
得分 3
4条评论:
Agreed +
完成的
Thank You! I appreciate it.
完成的
完成的
完成的
添加一条评论
添加你的答案
Fred 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,001
