How to Replace the Battery
How do I replace the battery on a MacBook Pro 15" Retina Display Late 2013
Aloke,
Unfortunately, the battery on the Late 2013 MacBook Pro 15" is nearly impossible to repair, due to being adhered to the case by an excessive amount of glue. It is quite likely the battery will break during disassembly. Furthermore, the battery covers the trackpad cable, which can easily shear during the battery removal process.
If you choose to attempt the repair, I would recommend, after removing all necessary screws, using an iOpener (iOpener) to soften the adhesive, and then using a plastic card to carefully pry up each cell, one at a time. The technique is explained in the guide for replacing the battery on the Late 2013 MacBook Pro 13" (MacBook Pro(13英寸,带有Retina显示屏,2013末)电池更换).
Hope it helps!
Kevin
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 270
Are you sure your battery is bad, it could just need some TLC and/or the SMC may need a reset
由 DanJ 完成的
