跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
MacBook won't stay on unless a key is held down entire time
So I just bought a used macbook (2008), previous seller said he had a liquid spill over the keyboard, all keys and trackpad work, but it won't stay on unless a key, any is held down (taped down) as soon as you let key go, 3-4 seconds later it'll shut off, any ideas? This is the first mac computer I've ever owned but I'm pretty comfortable taking it apart if needed to get it fixed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Can you give us the last four digits of your systems serial number so we can correctly identify your model.
完成的
Serial number: W8841ce61aq
完成的
Also took it apart today and cleaned the logic board, put it all back together but problem still persist, would a faulty keyboard cause this problem? Thinking of replacing it but don't want to spend the money and remove 50+ tiny screws if that has nothing to do with the issue I'm having
Thanks in advance
完成的
添加一条评论
1个答案
已选择的解决方案
Follow this IFIXIT guide: MacBook Unibody Model A1278 Upper Case Replacement follow it on taking the bottom cover off, then jump to Step 35 on disconnecting the keyboard. You'll then need to plug in a USB keyboard and using the power pads see if the system works correctly then. If it does you will likely need to replace the compete upper case or if you are lucky you might be able to clean and repair the keyboard.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Pierre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,995
