跳转到主内容
MacBook Unibody Model A1278 Upper Case Replacement
你所需要的
  1. MacBook Unibody Model A1278 Upper Case Replacement, Access Door: 步骤 1 中的图像 1,1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 2 中的图像 1,1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Upper Case Replacement, Battery: 步骤 3 中的图像 1,1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Upper Case Replacement, Lower Case: 步骤 4 中的图像 1,1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 5 中的图像 1,1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 Upper Case Replacement, Display Assembly: 步骤 6 中的图像 1,1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Be careful not to pull up on the cable as you remove it from the socket.
  7. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 7 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 7 中的图像 2,2
    • De-route the camera data cable from the channel in the optical drive.
  8. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 8 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 8 中的图像 2,2
    • Remove the following screws securing the camera data cable and right speaker to the upper case:
    • One 9.9 mm partially threaded Phillips screw
    • One 9.6 mm threaded Phillips screw
    • One 4 mm Phillips screw
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
    • The iSight cable has an eyelet through which passes the left-most screw in these pictures.
  9. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 9 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 9 中的图像 2,2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
  10. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 10 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 10 中的图像 2,2
    • Remove the following two screws from the display data cable bracket:
    • One 7 mm Phillips screw.
    • One 5 mm Phillips screw.
    • Lift the display data cable bracket out of the upper case.
  11. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 11 中的图像 1,1
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (4 screws total).
  12. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 12 中的图像 1,1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the 6 mm Torx screw from the lower display bracket.
  13. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 13 中的图像 1,1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  14. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 14 中的图像 1,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 14 中的图像 2,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 14 中的图像 3,3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
  15. MacBook Unibody Model A1278 Upper Case Replacement, Upper Case: 步骤 15 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement, Upper Case: 步骤 15 中的图像 2,2
    • Some 2.0 GHz A1278 MacBook Unibody logic boards do not have the necessary socket installed to accept the keyboard backlight ribbon cable attached to the upper case. The first and second pictures show logic boards with and without the socket installed, respectively. If your logic board does not have the backlight ribbon cable socket installed, the keyboard will work but the keys will not light up.
    • If your logic board does not have the socket installed to accept the keyboard backlight ribbon cable and you are installing a backlit upper case, simply tuck the keyboard backlight ribbon cable out of the way when you reinstall the logic board into the upper case.
  16. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 16 中的图像 1,1
    • Remove the single Phillips screw securing the hard drive bracket to the chassis.
    • This screw is captive to the hard drive bracket.
  17. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 17 中的图像 1,1
    • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
    • Lift the hard drive out of the chassis, minding the cable attaching it to the computer.
  18. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 18 中的图像 1,1
    • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
  19. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 19 中的图像 1,1
    • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
  20. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 20 中的图像 1,1
    • Lift the mid wall out of the upper case.
  21. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 21 中的图像 1,1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5 mm Phillips screws.
  22. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 22 中的图像 1,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 22 中的图像 2,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 22 中的图像 3,3
    • Use a spudger to pry the fan connector straight up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  23. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 23 中的图像 1,1
    • Lift the fan out of the upper case.
  24. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 24 中的图像 1,1
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  25. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 25 中的图像 1,1
    • Remove the single Phillips screw securing the subwoofer to the upper case.
  26. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 26 中的图像 1,1
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  27. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 27 中的图像 1,1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  28. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 28 中的图像 1,1
    • Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
  29. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 29 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 29 中的图像 2,2
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  30. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 30 中的图像 1,1
    • Lift the optical drive from its right edge and pull it out of the computer.
  31. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 31 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 31 中的图像 2,2
    • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
    • The hard drive cable and the plastic retaining block are attached together.
  32. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 32 中的图像 1,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 32 中的图像 2,3 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 32 中的图像 3,3
    • Peel back the small piece of black tape covering the right speaker cable.
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
    • Lift the subwoofer and right speaker assembly out of the upper case.
  33. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 33 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 33 中的图像 2,2
    • Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
    • Pull the IR sensor ribbon cable straight away from the logic board.
  34. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 34 中的图像 1,1
    • Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
  35. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 35 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 35 中的图像 2,2
    • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
    • Pull the keyboard ribbon cable straight out of its socket.
  36. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 36 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 36 中的图像 2,2
    • Remove the two 5 mm Phillips screws securing the keyboard flex bracket to the upper case.
    • Lift the keyboard flex bracket out of the upper case.
  37. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 37 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 37 中的图像 2,2
    • Remove the single Phillips screw securing the battery cable cover to the upper case.
    • Remove the battery cable cover from the upper case.
  38. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 38 中的图像 1,1
    • Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
  39. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 39 中的图像 1,1
    • Disconnect the battery cable connector by pulling it straight away from the logic board.
    • If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
  40. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 40 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 40 中的图像 2,2
    • Remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
    • Lift the bottom case clip out of the upper case.
  41. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 41 中的图像 1,1
    • Use the tip of a spudger to release the microphone from the upper case.
  42. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 42 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 42 中的图像 2,2
    • Remove the following five screws securing the logic board to the upper case:
    • Four 3 mm Phillips screws.
    • One 3.5 mm Phillips screw.
    • Remove the two 7 mm Phillips screws securing the DC-in board to the upper case.
    • Lift the logic board from its left edge and pull it out of the upper case.
  43. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 43 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 43 中的图像 2,2
    • If you are buying a new upper case from us, the next two steps are not necessary. Your upper case will come with these parts preinstalled.
    • Remove the following screws securing the battery connector cover to the upper case:
    • One 2.5 mm Phillips screw.
    • Two 1.5 mm Phillips screws.
    • Lift the battery connector cover out of the upper case.
  44. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 44 中的图像 1,1
    • De-route the battery connector cable through the gap in the upper case and remove it from the computer.
    • If you are installing an Upper Case that is missing the black bracket in the middle then transfer it from the old case to the replacement.
  45. MacBook Unibody Model A1278 Upper Case Replacement, Upper Case: 步骤 45 中的图像 1,1
    • Remove the six 1.4 mm Y0 Tri-wing screws securing the trackpad to the upper case.
  46. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 46 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 46 中的图像 2,2
    • Carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
    • De-route the trackpad cable through its slot cut into the upper case.
  47. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 47 中的图像 1,1
    • Pull the trackpad away from the outer edge of the upper case.
    • Remove the trackpad and set it aside.
  48. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 48 中的图像 1,1
    • In the following steps, you will be working on your new upper case.
    • Use a Y1 Tri-wing screwdriver to loosely install the 1.2 mm set screw included with your new upper case into its tapped hole near the middle of the trackpad opening on your new upper case.
    • Only tighten it about one turn for now.
  49. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 49 中的图像 1,2 MacBook Unibody Model A1278 Upper Case Replacement: 步骤 49 中的图像 2,2
    • Carefully insert the cable from your old trackpad through its slot cut into your new upper case.
    • Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
    • Pull the trackpad cable as you seat the trackpad into its void in your new upper case.
  50. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 50 中的图像 1,1
    • Insert a 1.4 mm Y0 Tri-wing screw into each of the outer holes drilled into the trackpad (two screws total).
    • You'll install the rest in a bit.
    • Tighten the screws all the way, then back them out about a quarter turn to aid in aligning your trackpad during the next few steps.
  51. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 51 中的图像 1,1
    • While continually trying to click your trackpad, gently tighten the Y1 Tri-wing set screw until the clicks return to their factory "feel".
    • You can tell when the screw is tightened just right by the noise it makes when the trackpad clicks. If the set screw is too loose, the trackpad will have excessive play before it clicks. If it is too tight, the trackpad will click too easily and won't make the characteristic loud mouse clicking noise.
  52. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 52 中的图像 1,1
    • Next, flip your upper case over so the keyboard side is facing up.
    • Align the trackpad so it is centered in its hole cut into the upper case.
  53. MacBook Unibody Model A1278 Upper Case Replacement: 步骤 53 中的图像 1,1
    • Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
    • If its alignment looks good, install the rest of the Y0 Tri-wing screws along the inner edge of the trackpad.
    • Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
结论
36等其他人完成本指南。
12条评论
On steps 50 and 53, be VERY careful to stop tightening the small, weak Y0 screws when you meet even just a little resistance. I made the mistake of tightening them too hard, and broke the tops off of two of them! Luckily I was able to remove one of the screws, but now one of them is stuck in one of the trackpad holes, unable to be removed.
seanheff17 - 回复
i did upgrade to backlit keyboard by adding the backlight to my keyboard. All works well thanks to this guide. Just try to keep all the screws in theyr place coz you can mistake them very easy and screwing the wrong screw in the wrong holle you may endup damaging the body(i hope it make sense). Good Luck
Nick - 回复
Actually I was looking for a way to remove only the keyboard to clean it, but since there is no guide I followed this one for most of the steps. No need to remove the display assembly and trackpad. But beware that after you remove the logic board and optical drive, you have to remove 3 layers (black, transparent and white) of foil covering the back of the keyboard and then there are like 50 absurdly tiny screws holding the keyboard to the frame. Also there are 2 screws in the upper left corner holding the power button which is connected to the keyboard through a small ribbon cable. After that you can lift the keyboard out easily.
Chris Popov - 回复
cheers mate thats the info i needed.
communit -
Tips: Label Screws by guide step number and size as you go. That way you can easily backtrack and any divergences between your machine's screws and the guide's will be a non-issue.
Also, be careful when removing and tightening screws. I stripped one of my screws and almost needed to call in the pros.
Use common sense throughout your fix. Nothing should be forced. Take breaks and return with a clear head.
Good luck!
pkchitan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 33
总计 85,433
