跳转到主内容
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
What would be the max. HD capacity when replacing internal drive?
I want to upgrade the internal hard drive. It appears to be a 30 gb . How large can I go as far as storage and the ibook still recognize it? Also what type of drive should I be looking for. Example " ATA 2.5 inch"..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Without jumping through hoops to get it formated, you should stay under 128GB. An ATA or IDE drive will work fine. Just stay away from the SATA drives. This drive will work just fine for you: [关联产品丢失或禁用: IF107-024]
Here's a bunch of new IDE drives up to 320GB that will work for you: http://eshop.macsales.com/Search/Search....|0&N=6885
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
James Brizendine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 704
