跳转到主内容
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
51 个问题 查看全部
问题已关闭
Engine siezed. Parked then wouldn't start
Engine won't start
Update
Took out starter Turned engine by hand. It won't turn.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you absolutely can not turn your engine over (remove the accessory belt and use a breaker bar with the appropriate socket on the crankshaft pulley) than you most likely have some severe engine damage. Not much you can do on a seized engine other than to replace it.
这个答案有帮助吗?
得分 2
添加一条评论
There is starter coil between battery and starter motor, try replacing this.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 199
