跳转到主内容
Repair and disassembly guides for GE Microwave ovens.
349 个问题 查看全部
How can I fix or replace the door handle of my microwave?
I have a GE Spacemaker XL Microwave oven Model JVM1340WW 002 mfg. Oct.1996. The lower part of the handle broke away from the screw that attaches it to the door of the microwave oven. I tried gluing it with "Goop" but that didn't last very long. The handle is still firmly attached by the upper screw, but I don't know how long that will work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I've been gluing and epoxying... I could've sworn I wrote this! lol So glad you asked and there was a good answer.
完成的
I fixed my GE Spacemaker Microwave Oven door handle by replacing the handle with 2 knobs (cost about $2.00). Has worked perfectly for the past 6 years!
完成的
添加一条评论
3个答案
已选择的解决方案
Hi there!
I found a couple tutorials for similar microwaves, hopefully they at least give you an idea of how to start!
Here's a youtube video guide for handle replacement, and a blog guide showing handle replacement on a standard spacesaver. (Also here's the user manual that has some support phone numbers). Best of luck!
这个答案有帮助吗?
得分 4
3条评论:
The blog was super helpful! I didn't even think that handle was replaceable. Thank you so much for posting!!
完成的
Thanks! With this information i was able to replace the door handle. Sounds like a common problem with the product but since it's 1996, and I've never had a problem, if the door handle is all that's broke, this is a good product. It's holding up great.
完成的
Where did you find new door handle? what is P/N and post link if possible? I have model JVM1870SK03 . Can you post link to search manual and parts?
完成的
添加一条评论
Hi @chughtaimb ,
Here’s a link to the parts for your microwave. The handle is part #1.
The link was only to show you the part and what it may cost.
There are other suppliers online that may suit you better.
Just search for JVM1870SK03 parts to get results for suppliers.
这个答案有帮助吗?
得分 2
添加一条评论
It is important to understand that the door plays a very important roll in keeping the microbe waves inside the unit. If the door doesn’t shut properly, it could leak out these harmful micro waves.
After any repairs to a door are made a Survey test needs to be made to test for any leakage. It can be done with a Survey meter or with a less expensive Survey test strips that can be purchased at some appliance parts stores or online.
Never continue to us a microwave with a damaged door or one that isn’t shutting properly. To do so is a safety hazard.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
tlc8216 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 96
总计 25,265
