跳转到主内容
加入维修社区 - 创建账户
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Hard Drive Upgrade Limit
What is the Hard Drive Size Upgrade limit for a
Apple Mac Mini 1.66GHz Intel Core Duo Computer, Model MA607LLA
original configuration -
1.66GHz Intel Core Duo processor
2MB L2 Cache
667MHz Frontside Bus
512MB of 667MHz DDR2 SDRAM (PC2-5300) on two DIMMs; supports up to 2GB
60GB 5400-rpm Serial ATA hard disk drive; optional 80GB, 120GB or 160GB drive2
Combo drive (DVD-ROM/CD-RW)
Built-in AirPort Extreme and Bluetooth 2.0
Apple Remote
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I have changed from 80GB to 500GB and it works just fine.
完成的
添加一条评论
3个答案
已选择的解决方案
Your machine uses a Serial ATA standard 2.5" hard drive. The largest drive I found that would work for you is 640 GB: http://www.ifixit.com/Apple-Parts/640-GB...
Here's an excellent tutorial on how to replace it: http://soledadpenades.com/2007/11/01/diy...
I just discovered this and thought it might be of interest: CPU can be replaced with a faster "Socket M"/"Socket M" Core Duo or Core 2 Duo
这个答案有帮助吗?
得分 4
1条评论:
Very nice guide. + Ralph
完成的
添加一条评论
Now that 1TB HDs with 9mm height are available, you can also upgrade the internal HD to 1 Terabyte. I just finished it and it works fine :)
这个答案有帮助吗?
得分 2
添加一条评论
The Western Digital Scorpio Blue (WD10TPVT) 1TB fits. Its has a12.5 mm height and I have one installed in the upper bay. Its snug but works fine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Bell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 9,205
