跳转到主内容
加入维修社区 - 创建账户
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
Why are my brakes locking up on me?
I have a 07 chevy equinox and the stabilitytrak light came on as my brakes started to lock up. Does anyone know what can be wrong. I have changed the booster and the master cylinder and yet the brakes are still locking up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I have the same problem Elantra 2004. I have replaced 2 calipers, brake line hoses and the master cylinder. Flushed the system twice. Yet my front brakes are still locking up. The power booster has no leaks and the pedal does not sink . What else is there?
完成的
I do not have ABS or traction control. I am at my wits end.
完成的
You do have abs and wheel sensors don't known that don't touch car
完成的
Tengo una Equinox 2007 y me pasaba lo mismo, despues de cambiar discos, pastillas y mordazas y todo seguia igual, cambie las mangueras que van a las mordazas, ya que estas estaban parcialmente obstruidas
完成的
添加一条评论
1个答案
已选择的解决方案
in both cases Antonio and funkybob this is a symptom of a bad abs pump. You may or may not get an abs light as the pump can be working enough to register but not enough to work properly. Hyundia are bad with there abs systems and there traction control . Chevs have a better system but when the stability control starts acting up on them the first place i look is at the abs pump. Hope this helps
这个答案有帮助吗?
得分 3
4条评论:
Thanks Jim but I do not have ABS or traction control.
完成的
funkybob does your car have esc light on the dash when you turn on the ignition and all the lights come on just before it starts?
完成的
It does have and for sure sounds wheel sensor on equinox
完成的
how big a deal and how expensive is it to check out the abs pump?
完成的
添加一条评论
添加你的答案
Antonio Nieto 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 7,843
