跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Why does my portafilter does not work properly?
Why does my portafilter does not drain all the coffee out? I have cleaned the machine many times and taken the portafilter apart but everytime I finish making the shot and take the portafilter out there are still a lot of pressure there and a lot of remaining mixture of coffee and water.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You may be using to course a coffee grind and it's clogging the filter.
这个答案有帮助吗?
得分 1
1条评论:
Actually, too fine of a grind will make it harder to push the water through; a too-coarse grind will result in weak coffee that almost gushes out. Tamping too hard will also produce a similar result, and really isn't necessary on this machine as it comes with a pressurized portafilter.
完成的
添加一条评论
添加你的答案
Mango 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,004
