跳转到主内容
The HP Compaq 6710b was released in 2007. It is a 15.4-inch widescreen business laptop for professionals, students, and users. It features a sturdy construction and a lasting battery life.
How can I stop my computer from overheating?
When I am using my laptop, sometimes it becomes really hot to the touch on the back of the laptop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
You can open your laptop and clean the dust out of it. Also you can reapply the thermal paste to the cpu. Make sure you clean your old paste off. Use a coffee filter to clean it off. That should make it run a little cooler.
如何涂散热膏
这个答案有帮助吗?
得分 1
1条评论:
Also use your laptop on a hard surface not your lap!
完成的
添加一条评论
First, try moving your computer to a flat surface to make sure the ventilation is not blocked. If that does not work, you should clean the internal fan, this will require some disassembly. The last thing you could try is replacing the heatsink thermal paste.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Khulan Orgil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 880
