跳转到主内容
The Envizen V100M Tablet, is a tablet PC made by Envizen Digital, a brand under Diamondking Inc. This company makes several tablets, all of which run an Android operating system.
What should I do when the screen on my tablet freezes up?
When using an application, browsing through my photo library, or just normal use the screen on my tablet sometimes freezes up. I am not sure what to do when this happens as I usually just wait until the battery dies. Is there any other way I can fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Does it allow you to turn it off?
这个答案有帮助吗?
得分 0
添加一条评论
Hi Josh,
If you are able to turn off the device, you could then turn the tablet back on hopefully resolving the problem, if not you could try to reset the tablet to fix the problem. For a more detailed guide on how to find out the problem see the troubleshooting guide.
Hope this helps,
Nick
这个答案有帮助吗?
得分 0
添加一条评论
I cannot put my PIN number in Everytime I try it do not see work I do not have one. So Everytime I put it in it say wrong PIN number so I cannot get in I need help or I'm going to return it
这个答案有帮助吗?
得分 0
1条评论:
Can I get some help
完成的
添加一条评论
Trying to reset tablet because I forgot pattern.Its now stuck on Fastboot. Won't turn off, or move to Recovery mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 771
