跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
97 个问题 查看全部
start engine then very shortly afterwards it cuts out!
I have a Honda CR-V 2 litre petrol 1998 model not owned it long and has been great. Can start engine no problem then very shortly afterwards it cuts out! Checked plug leads no spark have changed disi (albeit off a second hand one that was supposed to be a runner) but same fault happens. Replaced engine earth lead (at someone's suggestion) but will do the same thing! Can anyone help please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Barbara and Homer, Stalling or missing of an engine will usually set engine trouble codes. Some auto parts stores like Auto zone, Pep boys, Advance auto, etc. offer free diagnostic code reading. You can go there as a first step to help determine what the problem is. The staff at some of the auto parts stores are very knowledgeable and may able to offer good advice.
If no luck retrieving codes at one of the parts stores you may have to go to a good repair shop that have a little better equipment/ scanner that can read live data, which normally can pin point the problem with testing and diagnosing. Ask for an estimate on repair. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Is the idling rough?
这个答案有帮助吗?
得分 2
添加一条评论
The sound of the engine (RPM) is unstable, when in position N or P why?
这个答案有帮助吗?
得分 2
添加一条评论
I just got one to. and it does the same thing.I have been told that the ignition switch is the problem. and cost 127.00 the cheapest one I found on line.
这个答案有帮助吗?
得分 0
1条评论:
Did they say ignition switch relay or module. Have you checked the injecters
完成的
添加一条评论
添加你的答案
Barbara Flewitt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 19
总计 2,221
