跳转到主内容
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
Why won't my phone charge?
My phone stopped charging. But, I could still play music through the dock connector using my iHome clock radio. So, I assumed the battery was the issue. I replaced the battery and the phone still would not charge. So, I opened the phone and looked at the dock connector piece. I noticed that the water indicator is not completely white. Nor is it completely red (indicating water damage). But, it is about half red. Could the dock connector be the problem? Will swapping it out allow me to charge the phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Have you tried charging the iPhone via USB cable?
完成的
Yes. Since replacing the battery I tried charging via multiple USB cables. The phone doesn't charge.
完成的
添加一条评论
2个答案
已选择的解决方案
That's interesting. Since you replaced the battery and the problem still persists I would think that replacing the Dock Connector would be your next best step to take. The only other problem I could think of would be that the cable you were using was faulty, but it sounds like you've tried that already.
There is a repair manual for that procedure with a list of tools and parts you'll need, as well as the instructions to do the replacement.
iPhone 4 Verizon Dock Connector Replacement
Hopefully that'll solve your problem!
这个答案有帮助吗?
得分 2
2条评论:
Is it possible for sound to play through the dock but not be able to charge the phone?
完成的
I'm not a Computer/Electrical Engineer, so you might want to take this with a grain of salt, but from what I've read, the 30-pin connector handles different functions with different pins. So basically some pins handle power, some handle audio transfer, some handle video transfer, etc. My best guess is that either one of the pins is not functioning, or the route that power takes through the dock connector may be having problems.
Here's an image I found of the 30-pin connector functionality breakdown if you're interested. http://images.bwbx.io/cms/2012-07-26/tec...
完成的
添加一条评论
You need to turn it in to a repair shop for that model phone.
https://www.apple.com/support/iphone/rep...
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
DPCLAW1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 252
