跳转到主内容
The Kyocera Event is and Android based phone for Virgin Mobile. Released February 2013.
12 个问题 查看全部
Why will my Kyocera Event not turn on?
The phone will not power on when holding down the power button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
7个答案
最有帮助的答案
Hold down the power button
Press and hold down the power button (on the right side, top of the phone) to turn on the power.
Dead battery
1. There is a chance that your battery needs to be recharged. Try plugging in the phone to your charger and give it a few minutes before holding down the power button.
If the phone fails to turn on, it is likely that that battery no longer works and needs to be replaced. To replace the battery you need to find a compatible Kyocera battery, remove the phones backing, and remove the old battery. To remove the old battery you will lift up on the white tab labeled “pull” that is placed on the bottom of the battery.
If this step also fails it is possible that the charger may be faulty and needs to be replaced as well.
这个答案有帮助吗?
得分 3
添加一条评论
This was so helpful ok
这个答案有帮助吗?
得分 1
添加一条评论
I tried this and replaced both the battery and charger, and it still won't turn back on. Please help!
这个答案有帮助吗?
得分 0
添加一条评论
My phone just don't turn on or off ....it has a white line from top to bottom in the middle of the screen
Update (05/31/2017)
My phone does nothing
这个答案有帮助吗?
得分 0
添加一条评论
i keep putting my charger in and then it does'nt even works
这个答案有帮助吗?
得分 0
添加一条评论
If it is old can turn on
这个答案有帮助吗?
得分 0
添加一条评论
Activate a minute cell phone from a Sprint SIM card
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brett 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 22
总计 14,937
