Why will my Kyocera Event not turn on?
The phone will not power on when holding down the power button.
The Kyocera Event is and Android based phone for Virgin Mobile. Released February 2013.
Hold down the power button
Press and hold down the power button (on the right side, top of the phone) to turn on the power.
Dead battery
1. There is a chance that your battery needs to be recharged. Try plugging in the phone to your charger and give it a few minutes before holding down the power button.
If the phone fails to turn on, it is likely that that battery no longer works and needs to be replaced. To replace the battery you need to find a compatible Kyocera battery, remove the phones backing, and remove the old battery. To remove the old battery you will lift up on the white tab labeled “pull” that is placed on the bottom of the battery.
If this step also fails it is possible that the charger may be faulty and needs to be replaced as well.
声誉积分: 1
声誉积分: 1
声誉积分: 1
声誉积分: 1
过去的24小时: 5
过去的7天: 57
过去的30天: 231
总计 9,758
