跳转到主内容
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
39 个问题 查看全部
No Service No network
Hello.
My phone has been off for 2 days, fully charged it. and when i switch it on it ready no service... Cannot make calls nothing. Re-started still noting did Factory reset.. Still nothing.
Please help!!!
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 56
9条评论
My phones signal is gone for a while now
完成的
my mate7 has 1 month no signal, please help.
完成的
My Huawei honor p7i network is nt working please how do I do please help me out
完成的
My huawei phone is falling in the "no service "
How to relieve this
完成的
I just order a huawei honour 5 I install a sim but no signals
完成的
显示更多的4条评论
添加一条评论
30个答案
最有帮助的答案
1) check the SIM card is working properly
2) Check with your operator whether your IMEI blacklisted or not
3) update the firmware if available via OTA
4) Change the network mode : GSM only if signal comes change the network mode to 3G only if you found same issue the one of transceiver not working properly
这个答案有帮助吗?
得分 14
4条评论:
It wasnt helpful but the tranciever bit how do I fix it myself
完成的
How you did that my honor 9 its the some problem pleas
完成的
i have huawei honor 5x..sim its ok can detect,no problem..but signal no services..why yaa.. plis help me..
完成的
Sir
My mobile can not show the Sim he show no service plz help me my mobile y 7 prime 2019
完成的
添加一条评论
huawei p7 wifi not working
这个答案有帮助吗?
得分 5
3条评论:
Huawei p6 mobile network not working
完成的
Does your sims cards working please
完成的
I have Huawei y7 had network issues, I could not access internet, I just removed data saver and I was back,what I don't understand out of nowhere my phone started to have irritating issues NO NETWORK, I hope the magic works on you, next time I will definitely get another brand, I tend to believe Huawei phones are not reliable to its users
完成的
添加一条评论
这个答案有帮助吗?
得分 5
1条评论:
vai no Service network my mobile huawei scl-u31
完成的
添加一条评论
mobile network not available in huawei mobile
i have huawei honor 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Network options is also missing in phone now.
Please help me. i just bought few days before.
i am very Sad :(
should i sale it :(
这个答案有帮助吗?
得分 3
1条评论:
Same problem huawei p8lite
完成的
添加一条评论
I have a Huawei Ascend phone. was on a call yesterday and reception cut out no reception since in christchurch nz middle of the city!
这个答案有帮助吗?
得分 2
添加一条评论
Huawei Ascend G700 no network
这个答案有帮助吗?
得分 1
添加一条评论
i have huawei honour 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. I removed water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
这个答案有帮助吗?
得分 1
添加一条评论
Huaweiy330-u11 when inserted SIM it say emergencycall how to fix this problem ?
这个答案有帮助吗?
得分 1
添加一条评论
Try to turn on airplane mode, then turn it off. It helps me when i lose network signal
这个答案有帮助吗?
得分 1
添加一条评论
Network wcdma not work
这个答案有帮助吗?
得分 1
添加一条评论
how can i do how can ido
这个答案有帮助吗?
得分 1
添加一条评论
Huawei p20 lite no service
这个答案有帮助吗?
得分 1
添加一条评论
Huawei Mobile IC network is default
这个答案有帮助吗?
得分 1
添加一条评论
i got lycamobile sim card
when i put in on my phone called huawei p6
and when i want call some in said no service but for anther phone he does work but on huawei not why please help
what can i do make it work
这个答案有帮助吗?
得分 0
添加一条评论
huawei p8 lite no net appear after ten days i try all options no hope
这个答案有帮助吗?
得分 0
1条评论:
no net work shown i restart many times i remove sim many times ...still the same pls your help it's ten days back parched >>
完成的
添加一条评论
no service max mobile 424 model
这个答案有帮助吗?
得分 0
添加一条评论
My sim app is no long in my huawei so I don't have any sim setting it says only emergency calls only and I don't have any network show in my phone ?
这个答案有帮助吗?
得分 0
添加一条评论
How to set Sim menagement?
这个答案有帮助吗?
得分 0
添加一条评论
I Have This Problem Too
这个答案有帮助吗?
得分 0
添加一条评论
honor v9 no service how to this problam fix
这个答案有帮助吗?
得分 0
添加一条评论
Remove sim n put it back.
这个答案有帮助吗?
得分 0
添加一条评论
try hard reset if nothing's happen is the problem of your cellphone is crystal ic or antenna
这个答案有帮助吗?
得分 0
添加一条评论
Falling in water and when on then no service its taking Sim but no signal
这个答案有帮助吗?
得分 0
1条评论:
i have this problem too
完成的
添加一条评论
How do I get my new handset working it isn’t reading
Update (04/06/2019)
I just brought a phone it’s not reading my network or service rovider
这个答案有帮助吗?
得分 0
添加一条评论
Mate 20 lite Huawei no service :'( android 9.1.0.225
这个答案有帮助吗?
得分 0
添加一条评论
my huawei 3i fall into water when it fix it comes another problem no service appears i can't use it anymore i tried all the recommended steps but it didn't work please help
这个答案有帮助吗?
得分 0
添加一条评论
how to fix no service for huawei y7 prime 2019
这个答案有帮助吗?
得分 0
2条评论:
please help me with this
完成的
to my email yasirbofa@gmail.com
完成的
添加一条评论
Network is not working
这个答案有帮助吗?
得分 0
添加一条评论
When my phone is no service Huawei nova 8i how can i do?.
这个答案有帮助吗?
得分 0
添加一条评论
How can i do about myself
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
muzithembekwayo88 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 19
过去 30 天: 92
总计 114,254
