No Service No network
Hello.
My phone has been off for 2 days, fully charged it. and when i switch it on it ready no service... Cannot make calls nothing. Re-started still noting did Factory reset.. Still nothing.
Please help!!!
Thanks
1) check the SIM card is working properly
2) Check with your operator whether your IMEI blacklisted or not
3) update the firmware if available via OTA
4) Change the network mode : GSM only if signal comes change the network mode to 3G only if you found same issue the one of transceiver not working properly
这个答案有帮助吗?
It wasnt helpful but the tranciever bit how do I fix it myself
How you did that my honor 9 its the some problem pleas
i have huawei honor 5x..sim its ok can detect,no problem..but signal no services..why yaa.. plis help me..
Sir
My mobile can not show the Sim he show no service plz help me my mobile y 7 prime 2019
huawei p7 wifi not working
这个答案有帮助吗?
Huawei p6 mobile network not working
Does your sims cards working please
I have Huawei y7 had network issues, I could not access internet, I just removed data saver and I was back,what I don't understand out of nowhere my phone started to have irritating issues NO NETWORK, I hope the magic works on you, next time I will definitely get another brand, I tend to believe Huawei phones are not reliable to its users
mobile network not available in huawei mobile
i have huawei honor 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Network options is also missing in phone now.
Please help me. i just bought few days before.
i am very Sad :(
should i sale it :(
这个答案有帮助吗?
Same problem huawei p8lite
I have a Huawei Ascend phone. was on a call yesterday and reception cut out no reception since in christchurch nz middle of the city!
这个答案有帮助吗?
i have huawei honour 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. I removed water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
这个答案有帮助吗?
Huaweiy330-u11 when inserted SIM it say emergencycall how to fix this problem ?
这个答案有帮助吗?
Try to turn on airplane mode, then turn it off. It helps me when i lose network signal
这个答案有帮助吗?
i got lycamobile sim card
when i put in on my phone called huawei p6
and when i want call some in said no service but for anther phone he does work but on huawei not why please help
what can i do make it work
这个答案有帮助吗?
huawei p8 lite no net appear after ten days i try all options no hope
这个答案有帮助吗?
no net work shown i restart many times i remove sim many times ...still the same pls your help it's ten days back parched >>
My sim app is no long in my huawei so I don't have any sim setting it says only emergency calls only and I don't have any network show in my phone ?
这个答案有帮助吗?
try hard reset if nothing's happen is the problem of your cellphone is crystal ic or antenna
这个答案有帮助吗?
Falling in water and when on then no service its taking Sim but no signal
这个答案有帮助吗?
i have this problem too
How do I get my new handset working it isn’t reading
I just brought a phone it’s not reading my network or service rovider
这个答案有帮助吗?
my huawei 3i fall into water when it fix it comes another problem no service appears i can't use it anymore i tried all the recommended steps but it didn't work please help
这个答案有帮助吗?
how to fix no service for huawei y7 prime 2019
这个答案有帮助吗?
please help me with this
to my email yasirbofa@gmail.com
过去 24 小时: 6
过去 7 天: 22
过去 30 天: 98
总计 114,254
9条评论
My phones signal is gone for a while now
由 albert einstein 完成的
my mate7 has 1 month no signal, please help.
由 benchgrande34 完成的
My Huawei honor p7i network is nt working please how do I do please help me out
由 Sherif Deenbamsity 完成的
My huawei phone is falling in the "no service "
How to relieve this
由 Puwan Kiru 完成的
I just order a huawei honour 5 I install a sim but no signals
由 Heidi Brown 完成的
显示更多的4条评论
