跳转到主内容
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
60 个问题 查看全部
parts needed, where to buy, gear 2 backing and neo speaker
I am looking for somewhere to buy parts as I have two samsung gears one is the gear 2 and the other is a gear 2 neo. the neo needs a new speaker and the gear 2 needs a new backing as the one of the charging pins has broken off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Hi was my answer helpful? do you need any more help?
完成的
添加一条评论
4个答案
最有帮助的答案
there is no where that sells parts for the samsung gear that i know of.
the best thing to do is buy broken ones off ebay and strip them down for parts.
and if you don't have any moral decency, you can reassemble the broken ones and send them back to seller as original condition.
这个答案有帮助吗?
得分 1
添加一条评论
I'm looking for the display assembly (the upper part) my screen is only lines. I found it for only $29.99 if you are willing to part with your? My watch Works it just doesn't have a good display.
这个答案有帮助吗?
得分 0
添加一条评论
www.rounded.com have a lot of spare part for the gear 2 neo
这个答案有帮助吗?
得分 0
添加一条评论
I am looking for Samsung gear neo 2 part to buy in Ghana, as am having problem with the charging connector.
这个答案有帮助吗?
得分 0
1条评论:
I bought a connector off amazon (Kingboxs Charger Charging Connector for Samsung Gear 2 SM-R380 Gear 2 Neo SM-R381) 8.99 us.
完成的
添加一条评论
添加你的答案
ve3rma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,159
