跳转到主内容
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
How do I remove and replace the Matte Top cover?
I recently dropped my PS4 onto concrete. The fall resulted in the Top Back Left of the cover to be crushed in, and the Power button to stop functioning. I tested the console and it boots, loads and plays all disks fine. I decided to attempt a repair, but i hit a snag when i couldn't figure out how to take the matte side of the top cover off. I have taken out the TORX T8 security screws (T9 bit fit better though), but the cover just wont budge. Is there a specific way to pry the cover off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
Yes, there is a specific way to get it off...follow these steps (I'm assuming that the one black screw in the back [under the warranty sticker] has been removed along with the 2 silver ones on the top):
1) Put the console up on a table or workbench and get behind it. Pick it up in such a way that you can use your right hand to pull up on the corner where the power button is. Pull up on it several times pulling up a little more each time...you should feel part of it on the back "give way" or come loose.
2) Still using your right hand move over to the left corner. Put your palm on the top of the PS4 and curl your fingers under the lip. Press down with your palm while pulling up with your fingers. This is the hardest part and you may come away with a scratch of even a small cut on one of your fingers if it's especially tight.
3) If done correctly it will pop up. After it pops up you can just pull it off of the back of the case.
I hope this helps...good luck!
这个答案有帮助吗?
得分 5
7条评论:
Thanks a ton! I thought i was going to snap the cover but it came off eventually
完成的
Great...I'm glad you go it off...these can be tricky.
完成的
Where is the black screw under the warranty sticker I can't find it
完成的
I'm not sure why you can't find it...it's just right under the warranty sticker. Maybe the factory forgot to put it in!
完成的
I can't find the black screw under the warranty sticker. Where is it?
完成的
显示更多的2条评论
添加一条评论
I tried this and my power button no longer works.
这个答案有帮助吗?
得分 1
1条评论:
If your power button doesn't work then the cover either needs to be snapped down in place fully or there could be a problem with the metal contact that goes from the plastic cover to the copper pad on the motherboard.
I would try to give it a good push down where the button is and if that doesn't fix it then you may have to take it back off and have a look at the metal contact piece.
I hope this helps.
完成的
添加一条评论
I satill have 2 months warranty. If your like me you got your Playstation 4 in Dec. also. I'm thinking instead of me cutting myself, I'll just replace the unit using my warranty
这个答案有帮助吗?
得分 0
1条评论:
I would definitely use the warranty since you have it.
完成的
添加一条评论
how can i remove the back nail from the top
这个答案有帮助吗?
得分 0
添加一条评论
How do I remove the hard drive without Sony’s special screw?
这个答案有帮助吗?
得分 0
2条评论:
I saw you can use a tiny flat head if you swine small enough that is
完成的
*can find not swine
完成的
添加一条评论
添加你的答案
Haybale100 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 118
总计 65,122
