跳转到主内容
Repair guides and support for a wide range of small engines.
How do I cure this?
My ride on mower starts fine and ticks over as it should but when I release the brake and try to move forward or reverse the engine stalls then dies completely, it will not move in any direction. Also if I try to engage the blades the divine then stalls and cuts out. Any ideas how to stop this ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What make and model is your mower?
完成的
添加一条评论
5个答案
最有帮助的答案
Sounds like the seat safety switch is not depressed when you sit on the mower...assuming you have a rider mower or some other safety device like a blade break is stuck in on position
这个答案有帮助吗?
得分 1
添加一条评论
Does the machine stall when you only release the brake or do you have to try to move in a direction before it will stall?
这个答案有帮助吗?
得分 0
添加一条评论
Does your stall just when you let off of the break? or do you have to try and move in a certain direction before it stalls?
这个答案有帮助吗?
得分 0
添加一条评论
let start with a model number and a mfg. This sounds like a safety switch like an operator present switch under or near the seat. Depending on the model, it could be a pressure switch under the seat or near the frame/seat fold pivot that has a grounding tab contact there.
这个答案有帮助吗?
得分 0
添加一条评论
Check and make sure you don't have some rope or wire or something around your lawn mower blades stopping the blades from turning built up grass possibly without more information it sounds like something is stopping your blades from turning
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Seths mam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 586
