跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
211 个问题 查看全部
Where to buy flex ribbon cables?
I've been searching on eBay for all 4 flex ribbon cables that my PS3 Super Slim CECH-4001B uses, but I have found only ONE cable that is from that model.
Will these work?
Two of these 6-pin, one for the power button and the other for the lid open/close switch.
http://www.ebay.com/itm/Hot-6-pin-Eject-...
One of this 9-pin, this one goes under the power supply.
http://www.ebay.com/itm/NEW-9-Pin-0-5mm-...
And this 45-pin one is for the BluRay.
http://www.ebay.com/itm/Flex-Ribbon-Cabl...
Will the first two fit? are they too expensive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Did these cables work for you? I need a 9pin flex cable for my Super Slim.
完成的
Unfortunately I never got around to buying any, I convinced myself they were too expensive and decided to give up on my PS3.
完成的
添加一条评论
4个答案
I need a ribbon for the super slim that hook up under the power supply to the disk motor not for the laser please help me idk how pins it has pleasel et me know
这个答案有帮助吗?
得分 0
1条评论:
That's a 9-pin connector.
完成的
添加一条评论
Was a 9-pin accurate?
这个答案有帮助吗?
得分 0
添加一条评论
To anyone going through this problem the ribbon cable is a 9 pin forward 1.0 mm pitch 50mm length flex cable they can be obtained from eBay but from China
这个答案有帮助吗?
得分 0
2条评论:
PS all cables are like $10 for Blu-ray
完成的
Do you know the pitch for the 45pin as well as the 6pin cables as well?
完成的
添加一条评论
I have a question.. Hoping someone can help me.. I'm trying to figure out what white cable that is to the left of the disc reader is so I can purchase it!! So I can buy the right one
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel Velez 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 44
总计 5,377
