跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
MacBook Pro doesn't recognize replacement hard drive.
Hello everybody,
I am having a very weird problem with my MacBook Pro 15'' Mid 2009 model.
I recently damaged my hard drive, so I decided to buy a new one, which is exactly the same model as the one that I had. A Seagate ST9500420AS 500 GB 7,200 rpm.
Now the thing is that, although my previous drive is damaged, it can still be recognized by the disk utility when I boot from the Snow Leopard Installation DVD. On the other hand, for some reason, the new one is not recognized by the Disk Utility! What's more, I connected an older hard drive that I had, with Leopard installed in it and still it doesn't recognize it. But If I connect it to the USB, it recognizes it and it can boot normally to MacOS....
Isn't it weird? To recognize only the damaged hard drive?
Does anyone have any suggestions? I am dying to get my laptop working because I have many things to do this period. I appreciate your help.
John
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
+1 for interesting issue and well formulated question. Unfortunately I'm clueless about what could be wrong.. If I had the problem my gut would tell me to inspect the connectors closely..
完成的
When you say "recognized" or "not recognized" do you mean mounted, or, just listed in the left hand column?
完成的
+ for the good question. How did you damage the old hard drive? Where did the new hard drive come from? What was, and how did you hook up the "older drive" and what had it been in. I get the feeling that we don't have the full story here because this is not supposed to happen.
完成的
添加一条评论
2个答案
已选择的解决方案
So, to recap, USB works, but internal doesn't? It may be the Hard Drive Cable thats doing that... If not, its the logic board and it'll need to be replaced so lets hope its the cable.
这个答案有帮助吗?
得分 4
2条评论:
I agree. It is most likely the cable.
完成的
+ research
完成的
添加一条评论
Downgrade to EFI 1.6 instead of 1.7.
In 1.7 Apple has removed support for many 3rd party HDD and SSD drives.
Had same problem with OCZ Vertex 4 SSD, and found this solution in forums there.
这个答案有帮助吗?
得分 0
1条评论:
The difference between 1.6 & 1.7 was SATA versions of drives that could be used. So if you have an newer drive you needed to upgrade the firmware or jumper the drive down for the older I/O standard, review Apple T/N: http://support.apple.com/kb/DL853?viewlo... Apple did not remove any support of HD or SSD drives the standard changed! And you need to adjust for it depending on the system or drive.
完成的
添加一条评论
添加你的答案
jops 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 7,491
