跳转到主内容
Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
Why is my camera not turing on?
I keep using the power switch and the camera won't turn on. The screen is black and not making any sounds, what should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
最有帮助的答案
Hi John,
There are a couple things that might be wrong. The first thing that I suggest doing is replacing the batteries. If you do that and the camera still does not turn on, you may have to replace the power switch. Check here for more information.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
The lense won't extend. And tells me turn back on.
这个答案有帮助吗?
得分 0
添加一条评论
I had a battery leak in the battery compartment how can i repair my s2500hd camera?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Kemmitt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,073
