Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
John Kemmitt @johnkemmitt
声誉积分: 87
5
2
发帖于: 2015年4月9日
I keep using the power switch and the camera won't turn on. The screen is black and not making any sounds, what should I do?
这是一个好问题吗?
Megan Merlo @meganmerlo
声誉积分: 78
9
Hi John,
There are a couple things that might be wrong. The first thing that I suggest doing is replacing the batteries. If you do that and the camera still does not turn on, you may have to replace the power switch. Check here for more information.
Hope this helps!
这个答案有帮助吗?
nanascott @nanascott
声誉积分: 1
发帖于: 2015年11月5日
The lense won't extend. And tells me turn back on.
sanji20_05 @sanji2005
发帖于: 2017年9月30日
I had a battery leak in the battery compartment how can i repair my s2500hd camera?
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 14
总计 1,780
