跳转到主内容
The Macintosh Classic was a personal computer produced by Apple Computer, Inc. between 1990 and 1992.
110 个问题 查看全部
Transfer data from old SCSI hard drive
I pulled a SCSI hard drive from a dead Macintosh II desktop computer and would like to transfer the data to another more modern computer. Since I only want to do this one time I need an inexpensive solution to adapt the SCSI hard drive to either USB or Firewire. I could also hook up to an old PowerBook G3 to perform the transfer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
6条评论
Hello,
I have this problem, too.
I have a Mac Classic of the year 1992 and it works no more because there is rust on the mainboard (it was stocked since years in a rather humid environment).
I have succeeded in opening and extracting the HDD, a Quantum ProDrive LPS (there is also an Apple label: Hard Disk 40SC) with 50 pin SCSI connection.
I have also an iMac (that one in form of a half sphere) that is still working and has already USB, as well as Windows PCs.
How may I read the disc?
Only on Mac or also on Windows?
Best regards
F. J.
完成的
You'll need a Mac to use the files, but some data files are transferable to a Windows system (i.e. MS Word, MS Excel, Adobe PDF ...) or a newer Mac OS-X based system.
So if you don't have a Mac you can use a Windows system which also has the needed software to read Mac drives: 4 Ways To Read A Mac Formatted Drive In Windows. Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive.
You could even transfer your data to a more compatible drive for your Mac using the Windows system if you don't have a means to connect the SCSI drive to your Mac. Don't forget this older Mac system used OS-9 so the Mac you are planning on using here will need an older OS-X (Snow Leopard 10.6) to open the OS-9 Apps and its data.
完成的
Hi,
Thank You for Your answer.
The iMac has as well the OS 9 as an early Os X.
There is mainly one file I'm interested in: the database file of a geneology program.
If I succeed in retreiving it, the whole work will not be done: I'll need a program that can read the file.
Quote: "Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive."
I planned to use an adapter from SCSI to USB. Do You think that it could work? I could use it with the iMac, or if it doesn't work for some reason, with Windows.
完成的
Sadly, I don't have any experience with these SCSI to USB converters. What can I say, give it a try ;-} Please let us know if it worked!
完成的
Ok
Does someone else have an idea about this challenge?
完成的
显示更多的1条评论
添加一条评论
2个答案
最有帮助的答案
If you have a PowerBook with SCSI (pre firewire) and you can get the drive to work with that (probably OS 9 only) then you should be able to copy the contents to the PowerBook, then to a more modern format. It's probably only a couple of megabytes anyway. You are also facing the problem "what am I going to use to open these ancient files?"
这个答案有帮助吗?
得分 5
3条评论:
Thats the big question--will the data be available to modern software? + Ralph
完成的
The data, documents, music, movies, should have no problems moving. Of course the System 9 programs will not work. Word docs should import as well as most Adobe doc. Appleworks does have some problems with combined documents going into Pages.
完成的
Thanks for the help. I am getting closer to solving the problem by moving the drive to an old external hard drive. Now I just need a cable to the computer. The documents are Word or Excel so that shouldn't be a problem.
完成的
添加一条评论
Use a SCSI to USB adapter. Here's a link on how to do it:
http://www.topbits.com/how-to-connect-sc...
这个答案有帮助吗?
得分 5
1条评论:
Nice find + Ralph
完成的
添加一条评论
添加你的答案
Roy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 21
总计 17,252
