跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
Latch won't latch when closing...
Why won't the screen latch perform correctly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
First look at the upper hook to see if it is intact. Slowly close the id till it is almost closed to see if the magnet is pulling it down. See if anything is clogged in the lower receiver mechanism. The upper and lower cases may be out of alignment.
这个答案有帮助吗?
得分 1
1条评论:
I semi-close it, I can see the hook. Nothing in the lower case (FOD or crud). Case aligns perfectly.
This was a bottom case swap, (old lid, new bottom)
perhaps the cause ?
完成的
添加一条评论
添加你的答案
Mike Fink 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 980
