跳转到主内容
Part of Nokia's Lumia line of Windows smartphones. Announced July 2013.
35 个问题 查看全部
Battery not charging after screen replacement
The cracked screen was replaced and after reassembly it booted up normally.
Following that it is not recognised by a laptop for charging and did not power up normally after some time plugged in.
The battery is now flat and the phone unresponsive, what will fix this?
note: I also tried charging through another compatible micro to USB connector which did not work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I also have the same problem i have tried replacing the pcb or charger board after the digitizer was replace and still not working :S strange problem hope we find a fix!!!
完成的
Thanks Ben i did think that myself but wasn't sure. Anyway got one for £2 and it worked! So thanks again i probably wouldn't have bothered trying if you hadn't said that :)
完成的
添加一条评论
1个答案
已选择的解决方案
Check the flex cable connecting from the charger port to the logic board.
这个答案有帮助吗?
得分 1
1条评论:
The Nokia 7.2 ribbon cable is super sensitive. I had to use a micro telescope to see under the battery pack, because it pushes against the ribbon cable as it comes up to connect to the PCB. Slightest pressure, and connection fails. The CPB blue hot plate blue assembly pad was perfect to help with the fix
完成的
添加一条评论
添加你的答案
JW 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 566
